SIT8209 High Frequency Clock 100MHz 3.3V 20ppm LVCMOS
This 3.3 MHz 20 Hz 3.3 MHz clock will allow you to replace the original quartz on an audio module or add it to a lower jitter.
Reference : 12530
1,95 €tax incl.
1,63 € tax excl.
Shipping date: 16-04-2025.
SIT8209 100MHz Clock
3.3V 20PPM 15pF LVCMOS
This 100MHz frequency clock with a low drift of 20PPM provides stability and accuracy for a very low jitter rate. It operates at 3.3V, with an SMD/SMT standard LVCMOS output format.
It will advantageously replace any 100 MHz clock for compatible 32-bit DAC ESS SABRE SABRE 32-bit DAC ESS offering performance close to the US, UK or Japanese market benchmarks for a fraction of the price.
The qualities of a quality clock are well known to audiophiles who offer a less aggressive sound on high-definition files.
Attention, this LVCMOS 3.3V type clock requires a soldering station suitable for hot air type SMD components.
Do not attempt to weld with a conventional soldering iron.
Frequency100MHz
Frequency stability20ppm
Load capacity15pF
Supply voltage3.3V
Minimum supply voltage2.97V
Maximum supply voltage3.63V
Output formatLVCMOS
Type of connectionSMD/SMT
Minimum operating temperature-40C°
Max operating temperature+85C°
Dimensions3.2 x 2.5 x 0.75mm
