This type of potentiometer is superior to models with carbon track because the signal crosses only 2 metal resistances of high precisions. Equipped with high-quality film resistors, it is ideal for design where the improvement of preamplifiers instead of classic models from ALPS or compatible. It will also be indicated for the design of passive attenuator of high level of transparency.
This potentiometer is of type made before break. It is therefore able to switch without making any contact noise between each position.
Main Features :
- Resistor switching potentiometer
- Type: Logarithmic Stereo
- Resistance 10K
- Resistor Network: Ladder
- Made before break or cut
- 24 positions (0-23)
- Attenuation (0-75)
- High quality film resistors type E192 SMD 0.1% 25ppm
- Constant input impedance regardless of position
- Type Compact pin compatible with 6mm
- Diameter: 39mm
- Length: 81.2 mm
- Delivered: Units
- Weight: 82gr
Features of the provided button:
- Overall Diameter: 20mm
- Front Body Diameter: 17mm
- Overall Length: 17mm
- Compatible flat axis 6mm
- Aluminum and plastic finish
