Khozmo Acoustic 48-position Stereo Attenuator Shunt CMS 10k 1%
Reference : 8688
195,00 €tax incl.
162,50 € tax excl.
Shipping date: 30-12-2025.
A true jewel of audio workmanship, this magnificent 48-position stereo attenuator is entirely assembled by hand in Europe.
It is composed of 1% 100ppm RoyalOhm cms resistors and a CNC machined aluminum body that gives it a very high-end design.
This type of potentiometer is much higher than the carbon track potentiometers because the signal only crosses 2 resistors.
Wear is also much less important.
Characteristics:
  • Adjustment of the resistance of the axis (torque)
  • 48 positions
  • Stereo
  • Resistances: 10K RoyalOhm cms 1% 100ppm
  • > 50,000 cycles
  • Angle of indexing: 7.2 °
  • CNC machined
  • Solid aluminum body
  • Diameter of the shaft: 6mm
  • Mechanical on ball bearings
  • Shunt type: two resistors
  • Switching: MBB
  • Range: -60dB ... 0dB
  • Contacts: Solid Gold
  • Polished brooches
  • Extremely short signal path
  • Channel Balancing: +/- 0.1dB
  • Dimensions: 41 (width) x 48 (depth) x 45 (height) mm
  • Weight: 200g
https://www.audiophonics.fr/images2/8686/8686_attenuateur_stereo_in.jpg
[Img-15639-left-thickbox_default]
[Img-15640-left-thickbox_default]
[Img-13911-left-thickbox_default]
ShaftSmooth
Channel2 (Stereo)
Resistance (Ohm)10000.0
Tolerance (%)1
