KHOZMO ACOUSTIC Relay Volume Attenuator 10k 64 Steps MBB Switching Vishay Stereo
With this product, Khozmo offers a very high-end relay ladder volume attenuator with incredible audio performance. This is based on Omron HQ relays rather than mobile contacts and Vishay resistors.
By buying this product you get 31 loyalty points
Reference : 13650
319,00 €tax incl.
265,83 € tax excl.
Khozmo Acoustic
Atténuateur de Volume Ladder à Relais 64 Pas Commutation MBB Résistances Vishay Stéréo
With this product, Khozmo offers a very high-end relay ladder volume attenuator with incredible audio performance. This is based on Omron HQ relays rather than mobile contacts and Vishay resistors. In addition, the brand has designed an optical encoder that guarantees a much longer life span. In addition, the volume is adjusted in 64 steps from -64dB to 0dB. In addition, the attenuator benefits from MBB (Make Before Break) switching for which the new connection path is established before the next contacts are opened. This prevents the switching path from being confronted with an open circuit.
The attenuator comes with an LED display and a remote control to control the volume level, enable/disable mute mode and manage the display.
Product typeLadder relay volume attenuator
Switching typeMBB (Make Before Break)
Number of steps64
ResistorsVishay 10k
ChannelsStereo
Attenuation range-64dB to 0dB
Attenuation / Step1dB / step
RelayOmron
Mechanical life> 50000 cycles
Extremely short signal path-
Shaft diameter6mm
Voltage / Current5V 1A
Body materialAluminium PA11 CNC machined
Potentiometer total dimensions83.8 x 57 x 60mm
Shaft diameter6mm
Cutout diameter9mm
Max panel thickness7mm
Display PCB dimensions42.2 x 42.2
Display PCB fixing holes spacing31 x 31mm
ColorRed
Remote control batteries2x CR2032 3V (included)
Package1x Relay volume attenuator
1x Remote control
1x Display module
ShaftSmooth
Channel2 (Stereo)
Resistance (Ohm)10000.0
Tolerance (%)N/A
Very good quality
This attenuator is very good! The clicking sound of the relay is smooth and more quiet than the other I have tried. The display is tricky to be applied to the front panel of a chassis but functional, clearly visible, adjustable brightness.
This review has been posted for KHOZMO ACOUSTIC Relay Volume Attenuator 10k 64 Steps MBB Switching Vishay Stereo
With this product, Khozmo offers a very high-end relay ladder volume attenuator with incredible audio performance. This is based on Omron HQ relays...
