Potentiometer switched Stereo anti pop - Resistors 1% SMD 10k Flat axis LOG
Reference : 7358
14,90 €tax incl.
12,42 € tax excl.
Stereo Switched Potentiometer - Resistors 1% SMD 10k
This type of potentiometer is technically superior to the potentiometers with carbon track, the wear is also much less important.
the sound quality also increases with a "greater opening" and a better dynamic./ P>
The internal tracks now feature a "D Shaft Shape" profile in the form of an anti-pop "s" between each position of the potentiometer.
Thus the switching noises are strongly attenuated between each resistor protecting your loudspeaker
  • Potentiometer with resistor switch.
  • Logarithmic scale.
  • 21 positions.
  • Resistors SMD 1%.
  • Gold plated contacts
  • Diameter of the axis: 6 mm.
  • Flat axis: length 13 mm.
  • Profile of noise-canceling tracks "S" Shape Shaft.
https://www.audiophonics.fr/images2/7358/7358_STEPPED_ATTENUATOR_1.jpg
Profile of the tracks in the form of "S" anti-switching noise "Shape Shaft".
stepped attenuator potentiométre commuté.
https://www.audiophonics.fr/images2/5521/5521_STEPPED_ATTENUATOR_3.jpg
