Step ladder 24 positions 4 pôles Ø6mm Notched Axis 10K
Reference : 11874
39,90 €tax incl.
33,25 € tax excl.
This type of potentiometer is superior to the potentiometers with carbon track because the signal crosses only 2 metal resistors.
The wear is also much less important, which gives it a much longer life.
Main Features :
  • Potentiometer base with resistor switching
  • Axis notched
  • 4 poles
  • 24 positions
  • High quality American DALE Resistors
  • Resistance: 10KOhm
  • Constant impedance regardless of position
  • Overall Diameter: 40mm
  • Body Diameter: 30mm
  • Off-axis Length: 68mm
  • Length of shaft: 15mm
  • Diameter of the axis of the potentiometer: 6 mm
  • Drilling diameter: 9.5 mm
  • Weight: 70g
  • Delivered to the unit
schéma de câblage
ShaftNotched
ChannelN/A
Resistance (Ohm)10000.0
Tolerance (%)N/A
