Adjustable Discrete Voltage Regulator LM7805 +5V / +12V
This discrete voltage regulator has been designed to replace an LM7805 IC model (or LM7806 / 7809 / 7810 / 7812 with adjustment), in order to provide your audio system with a cleaner electrical signal. Its value of +5V is adjustable in the range +5V to +12V by means of a potentiometer. This controller provides low ripple, low noise and fast response.
Reference : 14041
13,90 €tax incl.
11,58 € tax excl.
DISCRETE VOLTAGE REGULATOR
LM7805, Adjustable, +5V / +12V
Régulateur de Tension Discret Ajustable LM7805 +5V / +12V
This discrete voltage regulator has been designed to replace an LM7805 IC model (or LM7806 / 7809 / 7810 / 7812 with adjustment), in order to provide your audio system with a cleaner electrical signal. Its value of +5V is adjustable in the range +5V to +12V by means of a potentiometer. This controller provides low ripple, low noise and fast response. The controller only uses high-quality components such as a Toshiba low noise triode, Vishay resistors, VX Tantalum capacitors or a Bourns precision potentiometer.
The regulator is set to a basic voltage of +5V.
Product typeDiscrete voltage regulator
RegulationTransistor NPN MJE15032G
Adjustable output voltage+5V to +12V
Output current1A
Operating temperature0°C - 125°C
Max. voltage (Vin)35V DC
Dimensions13.843 x 16.383mm
Output voltage (V)10.0
Output voltage (V)9.0
Output voltage (V)12.0
Output voltage (V)8.0
Output voltage (V)11.0
Output voltage (V)7.0
Output voltage (V)5.0
Output voltage (V)6.0
Output current (A)1.0
Input voltage (V)N/A
This discrete voltage regulator has been designed to replace an LM7805 IC model (or LM7806 / 7809 / 7810 / 7812 with adjustment), in order to...
