Adjustable Discrete Voltage Regulator LM7812 +12V / +25V
This discrete voltage regulator has been designed to replace an LM7812 IC model (or LM7815 / 7818 / 7824 with adjustment), in order to provide your audio system with a cleaner electrical signal. Its value of +12V is adjustable in the range +12V to +25V by means of a potentiometer. This controller provides low ripple, low noise and fast response.
Reference : 14042
13,90 €tax incl.
11,58 € tax excl.
DISCRETE VOLTAGE REGULATOR
LM7812, Adjustable, +12V / +25V
Régulateur de Tension Discret Ajustable LM7805 +5V / +12V
This discrete voltage regulator has been designed to replace an LM7812 IC model (or LM7815 / 7818 / 7824 with adjustment), in order to provide your audio system with a cleaner electrical signal. Its value of +12V is adjustable in the range +12V to +25V by means of a potentiometer. This controller provides low ripple, low noise and fast response. The controller only uses high-quality components such as a Toshiba low noise triode, Vishay resistors, VX Tantalum capacitors or a Bourns precision potentiometer.
Product typeDiscrete voltage regulator
Adjustable output voltage+12V to +25V
Output current1A
Operating temperature0°C - 125°C
Dimensions13.843 x 16.383mm
Output voltage (V)25.0
Output voltage (V)13.0
Output voltage (V)17.0
Output voltage (V)24.0
Output voltage (V)21.0
Output voltage (V)16.0
Output voltage (V)23.0
Output voltage (V)19.0
Output voltage (V)14.0
Output voltage (V)15.0
Output voltage (V)20.0
Output voltage (V)12.0
Output voltage (V)22.0
Output voltage (V)18.0
Output current (A)1.0
Input voltage (V)N/A
This discrete voltage regulator has been designed to replace an LM7812 IC model (or LM7815 / 7818 / 7824 with adjustment), in order to provide your...
