JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 1µF
Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a more balanced presentation without the excessive brightness of other high-end capacitors exaggerating the upper parts of the audio spectrum.
Reference : 12256
31,90 €tax incl.
26,58 € tax excl.
Shipping date: 23-01-2025.
Capacitor 100V 1µF
Jantzen Audio Alumen Z-Cap Condensateur 100V 1µF
This series has a finer dielectric than other capacitors on the market. This avoids memory defects in the insulators for a fast transfer of electrons between each winding (very low resistance in ESR series). Jantzen Audio Alumen capacitors are therefore particularly fast, offering harmonics worthy of the best oil paper capacitors, without the harmonic discolourations typical of the latter.
Jantzen Audio Alumen Z-Cap capacitors are therefore ideal for filtering high-end dome tweeters such as ScanSpeak Illuminator, Revelator, Dynaudio Esotec or SB Acoustics Satori. They are also ideal for Fountek NEO and Dayton AMT, ESS or RADIA tweeters. The welding wires are made of OCC Copper. These capacitors are also excellent for coupling in transistor amplifiers where the nominal voltage is sufficient (100VDC).
This is the model with 100VDC 1µF values.
Product typeCapacitor
DielectricPolypropylene (PP)
Aluminum metallization99.99%
Capacity1µF
DC Voltage100VDC
Tolerance+/-3%
Max temperature85°C
Very low inductance construction-
PolarizationNon polarized capacitor
Very low resistance serieESR
DimensionsØ14 x 50mm
Weight30g
Tolerance (%)3
Capacitor capacitance (µF)1
Rated voltage (V)100
Capacitor typeFilm capacitor
Capacitor formatAxial
2 reviews
parfait!... livraison ultra rapide++++++++++++
This review has been posted for JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 1µF
Présence et discrétion
Entièrement d'accord avec le post du 13 mars 2019 mais cette fois-ci sur Fostex T90 en premier ordre. Là aussi il a remplacé des SCR étain et autres. À retenir donc pour la rapidité des attaques, l'absence d'agressivité ou de brillance.
Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium...
