JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 5.6µF
Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a more balanced presentation without the excessive brightness of other high-end capacitors exaggerating the upper parts of the audio spectrum.
4.0 / 5
Reference : 12090
64,90 €tax incl.
54,08 € tax excl.
Jantzen Audio Alumen Z-Cap Condensateur 100V 5.6µF
This series has a finer dielectric than other capacitors on the market. This avoids memory defects in the insulators for a fast transfer of electrons between each winding (very low resistance in ESR series). Janzen Audio Alumen capacitors are therefore particularly fast, offering harmonics worthy of the best oil paper capacitors, without the harmonic discolourations typical of the latter.
Jantzen Audio Alumen Z-Cap capacitors are therefore ideal for filtering high-end dome tweeters such as ScanSpeak Illuminator, Revelator, Dynaudio Esotec or SB Acoustics Satori. They are also ideal for Fountek NEO and Dayton AMT, ESS or RADIA tweeters. The welding wires are made of OCC Copper. These capacitors are also excellent for coupling in transistor amplifiers where the nominal voltage is sufficient (100VDC).
Product typeCapacitor
DielectricPolypropylene (PP)
Aluminium metalization99.99%
DC Voltage100V DC
Tolerance+/- 3%
Max temperature85°C
Very low induction-
PolarizationNon polarized capacitors
Very low resistanceESR
DimensionsØ30 x 96mm
Weight84g
Tolerance (%)3
Capacitor capacitance (µF)5.6
Rated voltage (V)100
Capacitor typeFilm capacitor
Capacitor formatAxial
Jantzen Audio Alumen Z-cap
Excellents condensateurs qui rivalisent à l'écoute avec des concurrents nettement plus chers !
This review has been posted for JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 5.6µF
Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium...
