JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 8.2µF
JANTZEN AUDIO ALUMEN Z-cap Capacitor 2.2µF
Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a more balanced presentation without the excessive brightness of other high-end capacitors exaggerating the upper parts of the audio spectrum.
Reference : 12092
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 15-08-2024.
Jantzen Audio Alumen Z-Cap Condensateur 100V 8.2µF
This series has a finer dielectric than other capacitors on the market. This avoids memory defects in the insulators for a fast transfer of electrons between each winding (very low resistance in ESR series). Janzen Audio Alumen capacitors are therefore particularly fast, offering harmonics worthy of the best oil paper capacitors, without the harmonic discolourations typical of the latter.
Jantzen Audio Alumen Z-Cap capacitors are therefore ideal for filtering high-end dome tweeters such as ScanSpeak Illuminator, Revelator, Dynaudio Esotec or SB Acoustics Satori. They are also ideal for Fountek NEO and Dayton AMT, ESS or RADIA tweeters. The welding wires are made of OCC Copper. These capacitors are also excellent for coupling in transistor amplifiers where the nominal voltage is sufficient (100VDC).
Product typeCapacitor
DielectricPolypropylene (PP)
Aluminium metalization99.99%
DC Voltage100V DC
Tolerance+/- 3%
Max temperature85°C
Very low induction-
PolarizationNon polarized capacitors
Very low resistanceESR
DimensionsØ31 x 105mm
Weight106g
Tolerance (%)3
Capacitor capacitance (µF)8.2
Rated voltage (V)100.0
Capacitor typeFilm capacitor
Capacitor formatAxial
2 reviews
awesome caps
For many years i was convinced after testing various caps that pio caps was the only way to go for crossovers in horn loudspeakers. During a crossover modification , a wrong clumsy movement led to the destruction of the leads of an expensive pio cap. Replacing it was out of the question so I gave these jantzens a try and oh boy !!! These caps for the tweeter and midrange are really musical not so laid back as the pios but not as edgy as other boutique caps. Really impressed
This review has been posted for JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 8.2µF
Le meilleur rapport prestation prix du marché?
Le souci avec les bons condensateurs lorsque l’on veut filtrer un tweeter surtout si il descend assez bas en fréquence, c’est qu’ils sont chers et de faibles valeur.
Jantzen a tout compris avec ce condensateur Alumen, en proposant des valeurs assez larges , en tension dédiée au filtrage d’enceinte, avec un niveau qualitatif inédit qui place ce condensateur comme un mangeur de bas et moyens de gamme, et comme un outsider crédible des plus haut de gamme, à un tarif qui n’existe pas dans les condensateurs de cette qualité et avec des valeurs assez élevées disponibles.
Mis en place en remplacement du filtrage SCR d’origine de l’AMT Heil sur des Albedo, avec l’expressivité exceptionnelle et la descente bas en fréquence de ce transducteur de 96db de rendement une fois filtré, le résultat est très intéressant, moins mat que des SCR Etain que j’ai pu entendre sur cet AMT, moins brillant que des références plus haut de gamme, je dirais un juste positionnement des timbre en terme de contraste tout en gardant un haut pouvoir de résolution et d’aération.
Second usage de ces condos (un ami ayant refiltré le medium aigu de Cabasse avec), c’est pour moi LA référence de filtrage en medium aigu à tarif encore à peu près accessible.
Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium...
