ELNA SILMIC II RFS Aluminium Audio Capacitor 35V 330µF
Reference : 13354
2,90 €tax incl.
2,42 € tax excl.
Audio capacitor aluminum RFS series
These high-performance capacitors use silk fibers instead of traditional paper as terminals insulation.
The flexibility of the silk fiber is an ideal material for use in the field of precision audio. It reduces the stiffness of the peaks in the medium and high frequencies while enhancing massive and clear low frequencies.
The legs are in OFC copper for extremely low distortion.
Attention this is an electrolytic capacitor, so polarized: the positive pole is indicated by the longer leg.
TypeAluminum electrolytic capacitor
Capacitance330μf
VCC35 VDC
Tolerance20%
Temperature-40 + 85 ° C
Diameter (body):16mm
Length (body)25mm
Connectors spacing7.5mm
Connector diameter0.6mm
Connector materialsOFC
PolarizedYes
Connector lengthPositive: 20mm
Negative: 15mm
Tolerance (%)20
Capacitor capacitance (µF)330
Rated voltage (V)35.0
Capacitor typeElectrolytic capacitor
Capacitor formatRadial
