ELNA SILMIC II RFS Aluminium Audio Capacitor 35V 47µF
Elna Silmic II Condensateur audio RFS aluminium 35V 47.0uF
The Silmic II RFS (ROHS) series is a high-end series of capacitors from ELNA with superior acoustic qualities. The electrolytic separating paper used for this series contains silk fibers, allowing to attenuate vibrations. Thanks to this new design, the signal propagation speed has increased (ESR is reduced) and the reproduction is more dynamic.
Reference : 7693
0,90 €tax incl.
0,75 € tax excl.
ELNA Silmic II
ELNA Condensateur Audio RFS Aluminium 35V 47µF
Product typeCapacitor
Voltage35V
Capacitance47µF
Tolerance20% @ 20°C, 120Hz
Operating temperature range-40°C / +85°C
Lifetime1000h @ 85°C
Contacts materialOFC Copper
Tolerance (%)20.0
Capacitor capacitance47
Rated voltage (V)35.0
Capacitor typeElectrolytic capacitor
Capacitor formatRadial
Montage feedback
Bonjour ,
Augmente l'aération autour des musiciens , donne du relief et de la nuance , tirant vers l'aigu .Dynamique . Testé sur Naim Nac 72 . Mieux vaut rester sur les composants d'origine AMHA .
Bye
This review has been posted for ELNA SILMIC II RFS Aluminium Audio Capacitor 35V 47µF
The Silmic II RFS (ROHS) series is a high-end series of capacitors from ELNA with superior acoustic qualities. The electrolytic separating paper...
