ELNA SILMIC II RFS Aluminium Audio Capacitor 50V 1000µF
Reference : 13352
5,60 €tax incl.
4,67 € tax excl.
Audio capacitor aluminum RFS series
These high-performance capacitors use silk fibers instead of traditional paper as terminals insulation.
The flexibility of the silk fiber is an ideal material for use in the field of precision audio. It reduces the stiffness of the peaks in the medium and high frequencies while enhancing massive and clear low frequencies.
The legs are in OFC copper for extremely low distortion.
Attention this is an electrolytic capacitor, so polarized: the positive pole is indicated by the longer leg.
TypeAluminum electrolytic capacitor
Capacitance1000μf
VCC50 VDC
Tolerance20%
Temperature-40 + 85 ° C
Diameter:18mm
Length40mm
spacing connectors7.5mm
diameter connectors0.6mm
material connectorsOFC
polarizedYes
length legsPositive: 20mm
Negative: 15mm
Tolerance (%)20
Capacitor capacitance (µF)1000
Rated voltage (V)50.0
Capacitor typeElectrolytic capacitor
Capacitor formatRadial
Good item, original.
This review has been posted for ELNA SILMIC II RFS Aluminium Audio Capacitor 50V 1000µF
