JANTZEN AUDIO MKT Z-CAP Axial MKT Capacitor 100V 22µF
The MKT Z-Cap capacitors from Jantzen Audio are made of a high-quality metallized polyester film. They offer a longer life and better sound properties than electrolytic capacitors. When it is not possible to use metallized PP foil capacitors as an alternative to electrolytic capacitors for high value positions on crossovers due to their size, MKT-Zs are an excellent alternative.
Reference : 16928
8,90 €tax incl.
7,42 € tax excl.
Jantzen Audio MKT Z-Cap
Jantzen Audio MKT Z-Cap Condensateur MKT Axial 100V 22µF
The MKT Z-Cap capacitors from Jantzen Audio are made of a high-quality metallized polyester film. They offer a longer life and better sound properties than electrolytic capacitors. When it is not possible to use metallized PP foil capacitors as an alternative to electrolytic capacitors for high value positions on crossovers due to their size, MKT-Zs are an excellent alternative. Typically, MKT capacitors are offered with a voltage of 160VDC, but by using a thinner dielectric of 100VDC, MKT Z-Caps benefit from a reduced size. Because of their shape, they can be stacked more easily when coupled in parallel and therefore take up much less space than equivalent value Cross Cap capacitors.
Product typeAxial MKT capacitor
Voltage100VDC
63VAC
Tolerance±5%
Capacity22µF
Dielectric absorption factor< 0.5% @ 20°C
Dielectric thickness5µm
ESRVery low
Dissipation factorVery low
Auto-inductance< 15nH
Temperature range-55°C / +125°C
Metal layer thickness0.3µm
Metal layer conductivity1.2Ω/cm²
Dimensions17/23*46mm
Tolerance (%)5.0
Capacitor capacitance22
Rated voltage (V)100.0
Capacitor typeFilm capacitor
Capacitor formatAxial
The MKT Z-Cap capacitors from Jantzen Audio are made of a high-quality metallized polyester film. They offer a longer life and better sound...
