Utilisé en bypass couplé avec du Jantzen Zcap ce petit capuchon apporte de la dynamique, du détail, du gain avec des transitoires plus précises, à utiliser sans modération.
Capacitor 630V 0.1µF
Thanks to the latest winding technologies, Mundorf is able to manufacture its MCap ZN capacitors from ultra-pure, RoHS-compliant tinfoil. In the past it was necessary to add lead in order to obtain the required flexibility of the foil for capacitor winding. However, lead had a negative influence on the signal tone.
Thus, lead-free tinfoil means, in addition to the positive environmental aspects, an improved noise characteristic. The high conductivity ensures a lively sound reproduction of music.
Finally, the mass inertia of the tin foil prevents oscillations, which ensures a beautiful transparency and spatiality.
Product type | Capacitor |
Capacity | 0.1µF |
Voltage | 630VDC |
Tolerance | ±3% |
Dielectric | Polypropylene (PP) |
Electrode | Tin foil (6µm) |
Loss factor | 0.00002 @ 1kHz 0.00001 @ 10kHz |
Max temperature | 85°C (185°F) |
Dimensions | Ø12 x 25mm |
Wires diameter | Ø0.8mm |
Wires length | 30mm |
Tolerance (%) | 3 |
Capacitor capacitance (µF) | 0.1 |
Rated voltage (V) | 630.0 |
Capacitor type | Film capacitor |
Capacitor format | Axial |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
