MUNDORF MCAP EVO Capacitor 250V 330μF
MUNDORF MCAP EVO Capacitor 350V 330μF
Reference : 6898
125,00 €tax incl.
104,17 € tax excl.
Shipping date: 16-07-2024.
Condensateur Mundorf Mcap EVO
Mundorf Mcap EVO
Mundorf's Mcap EVO capacitors have gone through a high precision winding process before being hand-mounted in a shell layer specifically designed to reduce vibration and microphonics.
The particular shape of these capacitors as well as their robust construction allows for horizontal or vertical mounting without affecting performance or durability.
The inner coil has a narrow and tall profile. An unusual feature that results in a better ESR (equivalent resistance) and a reduced ESL (equivalent inductance). Indeed, a long and tight coil facilitates the signal path while increasing the number of windings traveled: redoubled efficiency and controlled size.
Dimensions
Capacitor Mcap EVO
TypeCapacitor Mcap EVO
Capacitance330 µF
Voltage250V
Tolerance±5%
Diameter75
Lengthr90
Connct wire diameter1,4
Connect wire length (A)50
Connect wire length (B)140
Maximum room temp85°C
DielectricPolypropylene (PP)
MetallisationAluminum
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Tolerance (%)5.0
Capacitor capacitance330
Rated voltage (V)250.0
Capacitor typeFilm capacitor
Capacitor formatAxial
