MUNDORF MCAP EVO Capacitor 450V 5.6μF
Reference : 6881
12,50 €tax incl.
10,42 € tax excl.
Shipping date: 16-07-2024.
Condensateur Mundorf Mcap EVO
Mundorf Mcap EVO
Mundorf's Mcap EVO capacitors have gone through a high precision winding process before being hand-mounted in a shell layer specifically designed to reduce vibration and microphonics.
The particular shape of these capacitors as well as their robust construction allows for horizontal or vertical mounting without affecting performance or durability.
The inner coil has a narrow and tall profile. An unusual feature that results in a better ESR (equivalent resistance) and a reduced ESL (equivalent inductance). Indeed, a long and tight coil facilitates the signal path while increasing the number of windings traveled: redoubled efficiency and controlled size.
Dimensions
Capacitor Mcap EVO
TypeCapacitor Mcap EVO
Capacitance5,60 µF
Voltage450V
Tolerance±3%
Diameter30
Lengthr27
Connct wire diameter1,0
Connect wire length (A)35
Connect wire length (B)60
Maximum room temp85°C
DielectricPolypropylene (PP)
MetallisationAluminum
Dielectric loss0.0002@1kHz · 0.0001@10kHz
Tolerance (%)3.0
Capacitor capacitance5.6
Rated voltage (V)450.0
Capacitor typeFilm capacitor
Capacitor formatAxial
Avis très positif
Installé sur un filtre pour la ligne du tweeter en remplacement d'un MKT Hingtat 100vdc 5.6uf, celui-ci se comporte moins agressif, plus enrobé et pétillant sur certaines notes se qui apporte une certaine émotion. Installé récemment, donc à voir dans le temps. Surement un prochain avis après rodage du composant.
This review has been posted for MUNDORF MCAP EVO Capacitor 450V 5.6μF
