This diameter reducer has been designed to allow ELECAUDIO's range of RS and RI connectors to accept cables from 8.5 to 16.5mm in diameter.
To obtain the smallest possible diameter, use 2 reducers per connector . So to reduce the diameter of 2 connectors for example, you need 4 diameter reducers .
Product Description:
Illustration: on the left, connector withoutthe washer, to the right the connector withthe washer (connector not included with the washer).
