Gold Plated Ø6mm (Set x4)
These gold plated banana plugs with cross-connection accept cables up to 6mm in diameter. They will allow you to finish the design of your speaker cables for a convenient and quick use, all at a low price.
Product type | Banana plugs |
Contacts plating | Gold |
Max cable diameter | Ø6mm |
Total dimensions | 48*Ø11mm |
Body dimensions | 28*Ø11mm |
Quantity | 4* banana plugs (2 with red ring, 2 with black ring) |
Max cable diameter (mm) |
Mounting type |
Connectic |
Connector |
Contacts Material (Connector) |
Contacts Plating (Connector) |
