JANTZEN AUDIO 000-0037 4N Copper Air Core Wire Coil 14AWG 4.7mH 73x60mm
Jantzen Audio Iron Core Coil - Permite 4N Copper 18AWG 6.80mH
Reference : 10492
55,90 €tax incl.
46,58 € tax excl.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance4,700mH
Tolerance+/-3%
Coil External Diameter73mm
Coil Internal Diameter35,00mm
Coil Height60mm
Wire Diameter1.60mm
Wire Section2.01mm²
AWG14 AWG
Weight1,334kg
Inductance (mh)4.7
