JANTZEN AUDIO 000-0963 4N Copper Air Core Wire Coil 14AWG 15mH 91x62mm
Jantzen Audio Iron Core Coil - Permite 4N Copper 18AWG 6.80mH
Reference : 10494
74,90 €tax incl.
62,42 € tax excl.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance15,000mH
Tolerance+/-3%
Coil External Diameter91mm
Coil Internal Diameter24,00mm
Coil Height62mm
Wire Diameter1.60mm
Wire Section2.01mm²
AWG14 AWG
Weight2,560kg
Inductance (mh)15.0
