JANTZEN AUDIO 000-1937 4N Copper Air Core Wire Coil 17AWG 0.18mH 38x15mm
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications. The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% ).
Reference : 15567
4,10 €tax incl.
3,42 € tax excl.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance0,18mH
Tolerance+/-3%
Coil External Diameter38mm
Coil Internal Diameter15mm
Wire Diameter1.2mm
Wire Section1.04mm²
AWG17 AWG
Weight91kg
Inductance (mh)0.18
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.  The coil benefits from a modern design,...
