JANTZEN AUDIO 000-1958 4N Copper Air Core Wire Coil 18AWG 0.22mH
JANTZEN AUDIO 000-1958 Air Core Wire Coil Copper Coil 4N 18AWG 6mH
Very high purity copper wire offering a distortion free inductance. It is suitable for all audio applications. The coil has a modern design, self-supporting and with a low tolerance to inductance (+/-3%).
Reference : 15797
23,90 €tax incl.
19,92 € tax excl.
Shipping date: 16-07-2024.
Bobine Jantzen Audio Copper 4N AIR CORE
Jantzen Audio Air Core Wire Coil
The power handling depends on the wire used, especially the thickness of the copper wire. The thicker the wire, the higher the power capacity. These are probably the most versatile coils on the market.
Product typeAir core wire coil
Material4N high purity copper
Inductance6mH
Tolerance+/-3%
External coil diameter61mm
Coil height30mm
RDC1.450 Ohm
Wire diameter1.00mm
Wire section0.823mm² (18AWG)
Weight0.462kg
Inductance (mh)6.0
Very high purity copper wire offering a distortion free inductance. It is suitable for all audio applications. The coil has a modern design,...
