JANTZEN AUDIO 4N Copper Air Core Wire Coil 18AWG 3.3mH
Jantzen Audio Iron Core Coil - Permite 4N Copper 18AWG 6.80mH
Reference : 10360
14,90 €tax incl.
12,42 € tax excl.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance3,300mH
Tolerance+/-3%
Coil External Diameter54mm
Coil Internal Diameter25,00mm
Coil Height30mm
Wire Diameter1.00mm
Wire Section0.79mm²
AWG18 AWG
Weight0,326kg
Inductance (mh)3.3
