JANTZEN AUDIO 000-0826 4N Copper Air Core Wire Coil 29AWG 1mH
The Jantzen Audio Air Core Wire Coil is made of high purity Copper wire, offering distortion-free inductance. This makes it suitable for all audio applications. The coil benefits from a modern, self-supporting design with a low inductance tolerance (±3%).
Reference : 14397
2,90 €tax incl.
2,42 € tax excl.
Jantzen Audio Air Core Wire Coil Bobine Cuivre 4N 29AWG 1mH
The Jantzen Audio Air Core Wire Coil is made of high purity Copper wire, offering distortion-free inductance. This makes it suitable for all audio applications. The coil benefits from a modern, self-supporting design with a low inductance tolerance (±3%). The power handling depends on the wire used and more particularly on the thickness of the copper wire. The greater the thickness, the higher the power capacity. Thus, Jantzen Audio Air Core Wire Coil is one of the most versatile coils on the market.
Product typeAir core coil
MaterialHigh purity 4N Copper
Inductance1mH
Tolerance±3%
RDC3.98Ω
Coil external diameter20mm
Coil internal diameter15mm
Wire diameter0.3mm
Section29AWG
Weight11g
Section (mm²)0.0642
Inductance (mh)1.0
The Jantzen Audio Air Core Wire Coil is made of high purity Copper wire, offering distortion-free inductance. This makes it suitable for all audio...
