JANTZEN AUDIO 000-1134 AIR CORE WIRE COIL Copper coil 4N 20AWG 0.95mH
Reference : 16381
4,50 €tax incl.
3,75 € tax excl.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance0,95mH
Tolerance+/-3%
Coil External Diameter38mm
Coil Internal Diameter15mm
Coil Height15mm
Wire Diameter0.8mm
Wire Section0.79mm²
AWG20 AWG
Weight0,092kg
Inductance (mh)0.95
