JANTZEN AUDIO 000-0817 4N Copper Air Core Wire Coil 20AWG 100mH
product
Reference : 13481
85,00 €tax incl.
70,83 € tax excl.
Jantzen Audio Coil Copper 4N AIR CORE
Copper coil Jantzen Audio
High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.
The coil benefits from a modern design, self-supporting and with a low tolerance to the inductance(+/-3% )
The power handling depends on the thickness of the copper wire.
The larger the cable, the higher the capacity.
Jantzen coils belong to the most versatile audio coils on the market.
TypeAir Coil Core
MaterialsHigh Purity Copper 4N
Inductance100,000mH
Tolerance+/-3%
Coil External Diameter72mm
Coil Internal Diameter25,00mm
Coil Height66mm
Wire Diameter0.80mm
Wire Section0.50mm²
AWG20 AWG
Weight1,628kg
Inductance (mh)100.0
