Natural Cotton sleeve for cable Ø 2-3mm
Reference : 6938
1,50 €tax incl.
1,25 € tax excl.
Gaine vendue au mètre
Gaine tressée 100% Coton naturel pour isolation de câbles.
  • Matière : Coton naturel tressé
  • Diamètre externe : 8mm
  • Diamètre interne : 2 à 3 mm
Il est conseillé de prévoir un peu de marge entre le diamètre interne de la gaine et le diamètre du câble que vous allez insérer dedans.
Vendue au mètre.
https://www.audiophonics.fr/images2/6938/6938_GAINEECRUE23MM_1.jpg
https://www.audiophonics.fr/images2/6938/6938_GAINEECRUE23MM_2.jpg
ColorWhite
MaterialCotton
Length (m)Sold by length
Max cable diameter (mm)3.0
Functional and aesthetic
I used these to add volume to the conductors in a home-made quad type speaker cable. The conductors were Audiophonics 4 sqmm silverplated hookup wire with PTFE insulation. The purpose was to reduce the potential for cross-talk between conductors.
This cotton sheath was perfect for the job. It was easy to insert the conductors and then stretch the sheath to a tight fit. The knots in the weave also made it easy to twitst the conductors together.
The natural cotton also adds a beautiful aesthetic to the cables, so I would recommend using this sheath as often as you can in your builds.
 (3)
This review has been posted for Natural Cotton sleeve for cable Ø 2-3mm
