The ViaBlue OFC tips permanently protect the oxidation and corrosion of the thin filaments of high-end cables.
Thanks to the crimping, the filaments can not break under the pressure of the screwing and thus cause false contacts due to broken filaments, causing a loss of sound.
ViaBlue cable connectors are manufactured from 99.99% pure oxygen-free OFC copper.
They have a large plastic insulation clamp that allows the cable to be inserted properly inside the nozzle.
They are available in several sizes for different cable sections.
Assembly is carried out using a suitable crimping tool.
To help you choose the right cable tip
Max cable diameter (mm) |
Section (mm²) |
Contacts Material (Connector) |
Contacts Plating (Connector) |
