VIABLUE Cable Protector Tips 16mm² OFC Copper (Set x15)
ViaBlue OFC ferrules provide long-term protection against oxidation and corrosion of the thin filaments that make up high-end cables. Thanks to the crimping, the filaments cannot break under the pressure of the screwing and thus cause false contacts due to filament breakage, resulting in sound loss.
ViaBlue cable ferrules are made from 99.99% pure, oxygen-free OFC copper. They have a wide plastic insulating collar that allows the cable to be inserted properly inside the ferrule.
They are available in various sizes for different cable cross-sections. The assembly is done with a suitable crimping tool.
Pour vous aider à choisir l'embout de câble qui vous convient
Max cable diameter (mm) | 5.7 |
Section (mm²) | 16.0 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Gold |
