VIBORG VB1020G Cable Crimping Tips 10mm²
These Viborg VB1020G crimping tips for cable are very useful when connecting cables to connectors, for example. They enable the pressure of the mounting screw to be exerted on the crimp, rather than directly on the stranded conductors.
Reference : 19047
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 22-04-2025.
VIBORG VB1020G Cable Crimping Tips with Insulation 24k Gold-Plated Copper 10mm² (Set x10)
Viborg VB1020G Crimping Tips photo
These Viborg VB1020G crimping tips for cable are very useful when connecting cables to connectors, for example. They enable the pressure of the mounting screw to be exerted on the crimp, rather than directly on the stranded conductors. They can also be used to assemble two sets of cables. High-quality, they are made of 24K gold-plated copper for optimum resistance to oxidation and corrosion. They are available in several sizes for different cable cross-sections. Assembly is carried out using suitable crimping tool.
Crimping tips dimensions
Product typeCrimping tips for cable
Body materialPure copper
Plating24k Gold
InsulationPTFE
Compatible cable cross-section10mm² (AWG7)
Total length26mm
Internal diameterØ4.5mm
Packagex10
Max cable diameter (mm)4.5
Section (mm²)10.0
These Viborg VB1020G crimping tips for cable are very useful when connecting cables to connectors, for example. They enable the pressure of the...
