VIBORG VB6018R Cable Crimping Tips 6mm²
These Viborg VB6018R crimping tips for cable are very useful when connecting cables to connectors, for example. They enable the pressure of the mounting screw to be exerted on the crimp, rather than directly on the stranded conductors.
Reference : 19053
23,90 €tax incl.
19,92 € tax excl.
Shipping date: 24-04-2025.
VIBORG VB6018RCable Crimping Tips with Insulation OFC / Silver / Rhodium Plated Copper 6mm² (Set x10)
Viborg VB6018R Crimping Tips photo
These Viborg VB6018R crimping tips for cable are very useful when connecting cables to connectors, for example. They enable the pressure of the mounting screw to be exerted on the crimp, rather than directly on the stranded conductors. They can also be used to assemble two sets of cables. High-quality, they are made of copper with triple plating layer of OFC / Silver / Rhodium for optimum resistance to oxidation and corrosion. They are available in several sizes for different cable cross-sections. Assembly is carried out using suitable crimping tool.
Crimping tips dimensions
Product typeCrimping tips for cable
Body materialPure copper
PlatingOFC / Silver / Rhodium
InsulationPTFE
Compatible cable cross-section6mm² (AWG10)
Total length24mm
Internal diameterØ3.5mm
Packagex10
Max cable diameter (mm)3.5
Section (mm²)6.00
VIBORG VB6018R Cable Crimping Tips with Insulation OFC / Silver / Rhodium Plated Copper 6mm² (Set x10)
These Viborg VB6018R crimping tips for cable are very useful when connecting cables to connectors, for example. They enable the pressure of the...
