JANTZEN AUDIO CROSS-CAP Capacitor 400V 10µF
Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the German, French and English references enjoys a very good design quality. They are ideal for parallel RL and RLC "plug" correction in parallel circuit, instead of low quality electrochemical capacitors.
Reference : 11770
5,50 €tax incl.
4,58 € tax excl.
Shipping date: 16-07-2024.
Jantzen Audio Cross-Cap
Capacitor 400V 10µF
Jantzen Audio Cross-Cap Condensateur 400V 1.5µF
The structure of these MKP capacitors is worthy of high-end constructions consisting of metallized polypropylene (ZnAl) film windings, all flooded with epoxy resin to hold the entire body together. The wires are made of 4N grade tinned copper. The parameters of these capacitors have a tolerance of 5% with respect to the European standard IEC 384-16. These capacitors provide a sound without any particular coloration and offer a great recoil of distortion.
Product typeMKP Capacitor
Capacitor filmMetalized (ZnAl) Polypropylene foil
Dielectric insulationPolypropylene
Capacitor typeHorizontal axial
Voltage rating400VDC / 250VAC
Operating temperature-40°C to +85°C
Capacitance10µF
Max tolerance5%
Loss factor at 1kHz (maximum)C < l uF : 5 * 104
C > l < 20 µF : 105
C > 20 µF : 105
Insulation resistance at 1kHzC < l µF : 5 * 104 MOhm
l < 20 uF : 3 * 104 MOhm
C > 20 uF : 104 MOhm
DimensionsØ26 x 36mm
Tolerance (%)5.0
Capacitor capacitance10
Rated voltage (V)400.0
Capacitor typeFilm capacitor
Capacitor formatAxial
4 reviews
Excellent rapport Q/P !
Adopté sur une correction // des woofers d'une paire d'EPOS Epic 5 en lieu et place de chimiques bipolaires basiques.
En effet, avant de me précipiter sur le changement des polypros en série avec les HP's, j'ai fait le choix de "nettoyer" en premier lieu ce qui est en général considéré à tord comme marginal avant d'aller plus loin.
Pour l'anecdote, les Epic 5 sont raccordées à un ensemble Nuprime DAC9X + STA9X eux-mêmes alimentés par un BADA LB6610.
Les Cross-Cap sont des polypropylènes métallisés (aluminium + zinc) la documentation constructeur ne dit pas s'ils sont non-inductifs.
Le résultat obtenu avec ces Cross-Cap est en l'occurence une sensation de "liant souple et aéré" accru, subtilement huileux avec moins de duretés.
La musique s'écoule avec moins d'efforts, de manière moins "carrée" et moins "in your face", au profit d'une sensation d'élégance tridimentionnelle.
Le ressenti de plus grande noblesse est plus que subtil.
Si je devais résumer mes sensations en quelques mots, je retiendrai "souplesse", "nuance" et "aération".
A ce tarif et dans cet usage-là, je ne lui voit aucun concurrent, seul de possibles manques de place sur les cartes des filtres ajoute un peu de difficulté à leur installation, le résultat valant nettement certaines contorsions d'installation.
Merci Jantzen, mention spéciale à Audiophonics pour ses délais de livraison tjrs aussi spectaculaires.
This review has been posted for JANTZEN AUDIO CROSS-CAP Capacitor 400V 10µF
Top
Pour une enceinte centrale
Parfait
Utiliser pour RC Zobel, très bon rapport qualité/prix.
Pourquoi s'en priver ?
Utilisés pour remplacer les condensateurs d'origine (27 ans) d'enceintes JM Lab DB 19, le son est bien meilleur et les aigus libérés et bien placés.
Je recommande.
Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe,...
