AUDIOPHONICS Digipi+ PRO Digital interface WM8804 for Raspberry Pi
4.0 / 5
Reference : 12150
21,90 €tax incl.
18,25 € tax excl.
Shipping date: 16-09-2026.
Please note that this product is compatible with PI2, PI3 and PI4 version 1.4, but not with PI4 version 1.5.
Here is a new and more elaborate version of the PI3 SPDIF Audiophonics DIGI+ PRO interface. Still featuring the WM8804 low jitter digital management chip and a Pulse PE-65612 audio isolation transformer, this interface allows Toslink coaxial and optical digital output to drive a DAC. A location on the printed circuit board allows an optional 75 Ohm BNC output to be soldered for the most demanding amateurs.
This version now includes two high-precision clocks for 16bit 44.1khz frequency multiples (CD format resolution) and 48khz multiple for 24bit 192khz high definition file resolutions. This technological contribution allows a better decoding accuracy at the exact frequency of the file sent to the DAC.
This version is delivered with an IR (infrared) cell and a connector dedicated to the GPIO of PI 3 and PI 2. Once connected to the GPIO connector, simply choose the right I2S HIFIBerry driver in its Raspberry Pi Audio distribution:
  • Moode AUDIO : driver HIFIBerry Digi et Digi+
  • Picore Player : driver HIFIBerry Digi et Digi+
To mount this DAC on a Raspberry PI 3 you will need the following spacers:
Characteristics:
  • 192khz SPDIF 24bit PCM interface
  • Screws not delivered
  • Output: Coaxial Spdif and Toslink optics
  • Supported sampling rates: 24bit 192 khz
  • This interface has two clocks 22,579 mhz and 24,576 mhz.
  • IR receiver, XBMC control with RC6 remote control (not included)
  • PCB dimensions: 86 x 56x 56x 22mm
  • Weight: 26g
  • I2S driver : HIFIberry DIGI +pro
This interface is compatible with Volumio using the Hifiberry Digi+Pro driver.
volumio digipi+pro
Follow the instructions given after installation:
volumio digipi+pro
volumio digipi+pro
InputGPIO
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipWM8804
Max sampling rate192kHz
Mounting typeTo connect
Interface chipWM8804
3 reviews
Rapport qualité/prix imbattable!
Très bon produit, fonctionne parfaitement avec le dtoverlay=hifiberry-digi-pro
J'utilise une configuration similaire à Moode Audio (upmpdcli+mpd) pour jouer du Qobuz depuis l'appli BubbleUPNP et cela fonctionne parfaitement.
Très bon timing, pas de problème contrairement à mes DAC USB Asynchrones ou pas...
This review has been posted for AUDIOPHONICS Digipi+ PRO Digital interface WM8804 for Raspberry Pi
Impressing SPDIF-source at low price
I use this Interface combined with a RPi 3B and Volumio (which I already used before). My DAC is the AK4495SEQ-Board from Audiophonics.
This Interface is absolutely astonishing: very tight bass, nice voices and superb positioning of the Musicians. I didn't await this quality for that price!
NOT the HifiBerry Product
I will update when I've had a chance to get this up and running with a proper review, however I wanted to highlight the fact that this is not the hifiberry product of the same name. This is a different product, and requires non standard volumio to function. I'm attempting to use picoreplayer instead and we'll see how that works.
Hi,
Yes indeed it's not an Hifiberry product (we have made our own range of Raspberry PI devices).
We dont sale any of their boards.
For us the product page is very clear about that.
This board need to use a custom version of software ex :
https://mega.nz/#!kNQx0QqB!m8bCN27mlG3E91llQQUy0ubweKF-qO5lyd81qf_z7wQ
