DAC Board for Raspberry Pi PCM5122 I2S 32bit 384khz DSD128
This DAC module for Raspberry is based on the use of a PCM5122 digital to analog conversion chip, allowing it to support PCM streams up to 32bit 384kHz and DSD128. It benefits from a complete connectivity, with I2S LVDS (HDMI), Optical Toslink, stereo RCA, 3.5mm headphone output and a coaxial input/output combo.
4.0 / 5
Reference : 16462
64,90 €tax incl.
54,08 € tax excl.
Shipping date: 24-09-2026.
To make this module work with a Raspberry Pi, you need to use the RPI DAC overlay driver (Moode Audio, Volumio, piCorePlayer, RuneAudio).
DAC Board
For Raspberry Pi PCM5122 I2S 32bit 384kHz DSD128
Module DAC pour Raspberry Pi PCM5122 I2S 32bit 384kHz DSD128
This DAC module for Raspberry is based on the use of a PCM5122 digital to analog conversion chip, allowing it to support PCM streams up to 32bit 384kHz and DSD128. It benefits from a complete connectivity, with I2S LVDS (HDMI), Optical Toslink, stereo RCA, 3.5mm headphone output and a coaxial input/output combo. A small OLED display provides simple and instant access to information about the audio stream and a series of three control buttons allow to act on the playback. The module is easily mounted on a Raspberry Pi via the GPIO port.
1220µF Capacitor
2PCM5122 DAC
32x 3.3V LDO
4PCM9211
5CS8422
6RCA Output
7Transformer for digital audio transmission
8Coaxial input / output
9OLED Screen
10SiTime oscillator
11Control buttons
12AT24C02 EEPROM
13Jack 3.5mm headphone output
14I2S LVDS output
15Differential driver
16MCU 32bit
17Optical Toslink output
18Power supply 5V
I2S Pinout
Connectivity
Sortie
RCAJack 3.5mmCoaxialOptiqueI2SDSD
EntréeI2S
Coaxial
DSD
Product typeDAC board for Raspberry Pi
Inputs1x GPIO
1x Coaxial (combined input/output)
Outputs1x Stereo RCA
1x Jack 3.5mm headphone output
1x I2S LVDS (HDMI)
1x Optical Toslink
DAC ChipPCM51222
Supported sampling ratesRCA / Jack 3.5mm : PCM up to 32bit 384kHz
Coaxial / Optical : PCM up to 32bit 384kHz, DSD DoP64
I2S : PCM up to 32bit 384kHz, Native DSD up to DSD128, DSD DoP up to DoP128
Output level (RCA / Jack 3.5mm)2Vrms
SNR (RCA / Jack 3.5mm)120dB
CompatibilityRaspberry Pi 2B / 3B / 3B+ / 4B
Supply voltage5VDC 300mA via GPIO or Jack DC
Dimensions56 x 65mm
InputGPIO
OutputJack 3.5mm
OutputOptical Toslink
OutputI2S LVDS via HDMI
OutputCoaxial SPDIF
DAC / ADC ChipPCM5122
Max sampling rateDSD128
Max sampling rate384kHz
Bien, mais quelques détails à revoir :-(
Bonjour à toutes et à tous,
Après l'achat de cette carte je l'ai montée sur mon Raspberry pi4 qui tourne sous moOde AUdio (la dernière version de Volumio est trop buggée et rAudio, ex Rune Audio, est un projet qui semble désormais en mort cérébrtale avec quelques modifications mineures par-ci par par-là).
L'installation est super simple et, après avoir choisi le bon "driver" I2S pour cette carte comme indiquée, il fonctionne sans souci. Seul truc à savoir il faut appuyer sur le bouton pour sélectionner "I2S In" afin d'avoir du son direct depuis le pi4.
L'écran est vraiment sympa pour savoir si le pi4 joue bien ce qu'on lui demande de jouer dans le bon format. Il affiche manifestement correctement le taux d'achantillonnage (44.1, 48 ou 96khz) mais le mitrate est faux : il affiche 32bits au lieu de 24bit... Alors de là à croire qu'il upsample il n'y a qu'un pas. Or je voudrais avoir la certitude qu'il ne sort pas un message "faussé". Bug d'affichage ou vraie difficulté ?
Par ailleurs, si la sortie casque a l'air d'être suffisamment puissante, il faut l'utiliser avec des casques ULTRA gourmands... Pourquoi ? Parce que le régalge ne s'opère que sur 8 niveaux. Inutile de dire que du coup si le réglage "5" est un peu insuffisant, le réglage suivant "6" est vraiment fort... Un régalge sur une douzaine de niveaux n'aurait pas fait de mal si ?
En conséquence, je ne mets qaue 4 étoiles. Mais 4 étoiles quand même pour la simplicité d'utilisation, pour la qualité du son, pour la puissance de la sortie casque et pour le petit écran, qui reste quand même une petite aide...
Et quand je parle de qualité du son, franchement, je trouve que c'est vraiment vraiment BON. Même comparé à des propositions bien plus "puissantes" et dédiées à l'écoute au casque : c'est franchement pas mal pour mes oreilles. Peut-être que la puce 5122 fait des petites merveilles ou que simplement la différence me fait croire que c'est bon... Quoiqu'il en soit, je pense que le son qui sort de cette petite carte à 65€ peut rivaliser avec un combo DAC et Ampli casque jusqu'à 8 fois plus cher. Alors pourquoi se priver ?
This review has been posted for DAC Board for Raspberry Pi PCM5122 I2S 32bit 384khz DSD128
This DAC module for Raspberry is based on the use of a PCM5122 digital to analog conversion chip, allowing it to support PCM streams up to 32bit...
