The HiFiBerry DAC2 ADC Pro is a DAC/ADC module for digital-to-analog and analog-to-digital conversion specially designed for use with a Raspberry Pi (A+, B+, 2B, 3B, 3B+, 4B+, Zero, 5). This sound card therefore features both analog and digital inputs, offering a wide range of uses, whether for recording or audio playback.
The module is based on two Burr Brown chips, a PCM5122 DAC chip and a PCM1863 ADC chip, enabling it to support PCM streams up to 32bit 192kHz. An optimized clock circuit completes the package, reducing jitter. The HiFiBerry DAC2 ADC Pro is also compatible with the HiFiBerry DSP add-on and Alsa Mixer for volume control.
Signal input is via 40-pin GPIO (digital) or 3.5mm jack/PCB connector (analog), while output is via RCA or PCB connector. The module is powered by the 40-pin GPIO, and therefore by the Raspberry Pi, and a PCB connector enables an additional 5V supply to be taken from the Raspberry Pi.
Key features:
1 | 40-Pin GPIO |
2 | PCB connector +/-5V |
3 | Microphone bias jumper* |
4 | Balanced/unbalanced analog input on PCB connector (J4) |
5 | 3.5mm jack analog input |
6 | Stereo RCA output |
7 | Analog output on PCB connector (J5) |
8 | PCB connector for DSP |
*You need to close both jumpers to provide a bias current suitable for a microphone.
4 : Balanced/unbalanced analog input on PCB connector (J4) | |||
In R- | 1 | 2 | In R+ |
GND | 3 | 4 | GND |
In L+ | 5 | 6 | In L- |
7 : Analog output on PCB connector (J5) | |||
+5V | 1 | 2 | R |
GND | 3 | 4 | GND |
+5V | 5 | 6 | L |
Product type | DAC/ADC module |
DAC/ADC chips | DAC PCM5122 ADC PCM1863 |
Inputs | 1x 40-pin GPIO 1x 3.5mm jack 1x Balanced/unbalanced analog input on PCB connector |
Outputs | 1x Stereo RCA output 1x Analog output on PCB connector |
Compatibility | Raspberry Pi A+, B+, 2B, 3B, 3B+, 4B+, Zero, 5 |
Max. input voltage | Unbalanced: 2.1Vrms Balanced: 4.2Vrms |
Max. output voltage | 2.1Vrms |
SNR | DAC : 110dB ADC : 112dB |
THD+N | DAC : -93dB ADC : -90dB |
Frequency response | 10Hz-70kHz (-3dB) |
Input gain | -12db to 32dB |
Supported sample rates | PCM 24bit 192kHz |
Power supply | Via Raspberry Pi |
Power consumption | < 0.3W |
Dimensions | 5.5 x 6.5 x 1cm |
Weight | 30g |
Package | 1x HiFiBerry DAC2 ADC Pro DAC/ADC module |
Input | GPIO |
Input | Jack 3.5mm |
Input | PCB Connector |
Output | RCA |
Output | PCB Connector |
DAC / ADC Chip | PCM1863 |
DAC / ADC Chip | PCM5122 |
Max sampling rate | 192kHz |
