HIFIBERRY DAC8x DAC Board for Raspberry Pi 5
The HiFiBerry DAC8x is a high-resolution digital-to-analogue converter for the Raspberry Pi 5. It is a special sound card for the Raspberry Pi, optimised for a specific use case: high-quality audio playback at an affordable price.
Reference : 19621
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 24-04-2025.
HiFiBerry DAC8x DAC Board for Raspberry Pi 5 Burr Brown 24bit 192kHz
HiFiBerry DAC8x : Front view
Key features:
  • 8-channel audio output.
  • Four 192kHz/24bit Burr-Brown DAC chips.
  • Direct connection to the Raspberry Pi, no additional cables required.
  • No soldering required, it comes in the form of a prefabricated kit. All you have to do is plug it into your Raspberry Pi.
  • Compatible with all Raspberry Pi 5.
  • Directly powered by the Raspberry Pi.
  • Two ultra-low-noise linear voltage regulators for optimum audio performance.
  • HAT compliant, EEPROM for automatic configuration.
  • Supplied with all the components needed for assembly. 4 M2.5x12mm spacers to fix the board to the Raspberry Pi.
Product typeDAC Board for Raspberry Pi
InputGPIO 40 pins
Outputs4x Jack 3.5mm TRS
CompatibilityRaspberry Pi 5
Max output voltage2.1Vrms
Signal-to-noise ratio (SNR)112dB
Total harmonic distortion more noise (THD+N)-93dB
Frequency response10Hz - 70kHz (-3dB)
Supported sampling ratesPCM up to 24bit 192kHz
Consumption< 0.3W
Dimensions55 × 65 × 25 mm
Weight30 g
Package1x HiFiBerry DAC8x
4x M2.5x12mm spacers
HIFIBERRY DAC8x DAC Board for Raspberry Pi 5 Burr Brown 24bit 192kHz
The HiFiBerry DAC8x is a high-resolution digital-to-analogue converter for the Raspberry Pi 5. It is a special sound card for the Raspberry Pi,...
