HIFIBERRY DIGI2 PRO V2.2 Digital Interface SPDIF for Raspberry Pi 24bit 192kHz
The HiFiBerry Digi2 Pro V2.2 is a stereo SPDIF interface module designed to work with a Raspberry Pi. The assembly is very simple. In addition, the Digi2 Pro offers very good performance, including the integration of isolation on the output, low noise linear regulators or two low jitter clocks.
Reference : 16526
66,90 €tax incl.
55,75 € tax excl.
Shipping date: 06-05-2025.
New board release 2.2 of DIGI2 PRO that is now fully compatible with the latest Raspberry Pi4 hardware (and all other Raspberry Pi’s with the 40-pin header).
HiFiBerry Digi2 Pro v2.2
HiFiBerry Digi2 Pro Interface Numérique SPDIF pour Raspberry Pi 24bit 192kHz
The module has an optical Toslink output and a coaxial output. A slot also allows to add a BNC output to solder. An extension connector also offers the possibility to add a DSP module (not supplied) in order to adapt the sound reproduction to your listening, your room and your equipment.
1GPIO 40 pins Input
25V Supply voltage
3DSP Connector
4Isolation ground jumper
5Optional BNC connector
6Optical Toslink output
7Coaxial output
Product typeSPDIF Digital interface
InputGPIO 40 pins
Outputs1x Coaxial
1x Optical Toslink
ChannelStereo (2)
(Dolby Digital, DTS support)
Supported sampling ratesPCM up to 24bit 192kHz
Dimensions5.5 x 6.5 x 1.5cm
Weight25g
Consumption< 0.3W
Input
  • GPIO
Output
  • Coaxial SPDIF
  • Optical Toslink
DAC / ADC Chip
  • NC
Max sampling rate
  • 192kHz
The HiFiBerry Digi2 Pro V2.2 is a stereo SPDIF interface module designed to work with a Raspberry Pi. The assembly is very simple. In addition, the...
