IAN CANADA DUAL MONO PLUS DAC ES9038Q2M HAT Raspberry Pi / I2S & SPDIF / PCM DSD
Ian Canada 9038Q2M dual mono DAC HAT is a very high level of DAC for Raspberry Pi. It uses two chips ES9038Q2M SABRE 32-bit each working in mono.
Reference : 13971
109,00 €tax incl.
90,83 € tax excl.
This product has been replaced by the new version, the IAN CANADA DUAL MONO MKII DAC ES9038Q2M.
To be used, this product must be combined with ESS SABRE 90X8 controller, or to the MONITORPI PRO Control center.
Ian Canada 9038Q2M
DAC Dual Mono 768kHz - 32bit PCM / DSD1024 Native & DOP256
Ian Canada Dual Mono ES9038Q2MPi DAC HAT Raspberry Pi / I2S & SPDIF / PCM DSD
Ian Canada 9038Q2M dual mono DAC HAT is a very high level of DAC for Raspberry Pi. It uses two chips ES9038Q2M SABRE 32-bit each working in mono. That is to say that each of these chips uses 100% of its computing power for a single channel of the stereophonic signal for a sound restitution of exceptional clarity.
The ES9038Q2M Dual Mono DAC is remarquable because of its lack of output stage: This module is made exclusively for performing digital / analog conversion quality. It must be connected to an output stage that can be selected from existing compatible components or self-assembled according to your own specifications.
In other words: DAC Ian Canada Raspberry Pi is a hyper efficient DAC (double 9038Q2M), which imposes no particular output stage to the makers. They can then freely meditate the best integration strategy depending on the type of project solutions, budget and compliances.
Enhancements of the ES9038Q2MPi Dual Mono Plus DAC HAT
  • 3 separated power rails for AVCC, DVCC and VCCA.
  • Optimized PCB layout with 2oz double thickness copper layers for lowest possible ground noise level.
  • To make it focus only on the sound quality, all unrelated circuits were removed.
  • Enhanced ultra low ESR decoupling networks for better voltage rails quality.
  • New XO socket design makes it possible to swap/upgrade to better local clock.
  • Very easy to switch to SYNC mode by just removing local XO from the socket and plugging an U.FL MCLK cable. Thus, the SYNC mode will have less noise and no longer need the jumper switch.
  • Ready to workd with high quality 3.3V ultra capacitor power supplies.
Double ES9038Q2M
Dual Mono DAC Pi employs two DAC chip ES9038Q2M. It is not only ESS flagship product, it is also one of the best current material solutions for high-fidelity digital audio decoding.
It uses famous architecture HyperStream 32 BIT 768kHz and a support native DSD 1024. Dac chips are also equipped with advanced reconstruction filters and have an excellent finesse in dithering.
Optimised power supply
The basic module is powered by three separate power supply units. These form the symmetrical power supply stage, which is responsible for supplying each of the DAC chips with clean power. The DVCC, FCCA and AVCC rails are isolated. It is therefore possible to supply them independently with 3.3V / 100mA (minimum) for optimum performance, or to bridger them to use only one power supply. It is recommended to supply the DAC directly with 3.3V supercapacitor modules or LiFePO4 batteries, to obtain the best possible sound reproduction.
The 9038Q2MPi consumes about 50mA on average, with the MCLK 50MHz in asynchronous mode (default).
Synchronous or asynchronous clock
The module can use its own internal clock 100MHz (asynchronous) and can work with an external clock (synchronous) of 22.5792MHz to 98.3040MHz. Properly used, this second mode offers unmatched performance from the viewpoint of jitter. It will therefore naturally favored by the most discerning audiophiles.
When used in synchronous MCLK guide (e.g. mounted on a FifoPi with galvanic isolation and removable clocks), this dual DAC Mono 9038Q2M operates from an external clock signal. In other words, it is very easy to inject a clocks signal without requiring direct circuit modification  (just use a jumper to enable / disable async mode).
Note, however, that to enjoy the SYNC mode in all its qualities, it is necessary to set the bandwidth of the digital phase locked loop (DPLL). This operation requires an ESS controller (like the ECCS, specially designed for this or any driver capable of editing the register of a ESS9038Q2M chip).
Scalable DAC module
If the use of a ESS controller is perfect for fine-tuning the DAC chips (the controller Ian Canada FifoPi the same manufacturer allow the module to work TrueSync mode), there are plenty of upgrades that can be done by the user.
Depending on your goals you may :
- Install a FiFoPi / Isolator between Raspberry Pi and DAC
- If you can not work with a reclocker (FifoPi), the clock on the DAC itself is  removable.
- Install an ESS controller to change the DAC settings on the fly
- Customize the powering system to improve audio performance.
- Install an output stage suitable for your installation, its constraints and your personal preferences
Dimensions and distances
9038Q2MPI DAC fully mounted with all its accessories
Only the DAC module is delivered. Accessories and other HAT modules are not supplied and must be purchased separately.
TypeModule DAC
DAC chip2x ES9038Q2M
Mounted dual mode Mono
InputsGPIO (RPI)
SPDIF
Outputsbalanced output connector 2.54mm
2 x 5 pins
Supported frequencies768kHz 16/24/32 bit PCM
DSD 1024
DSD256 (DOP / SPDIF)
Auto detection of signal typeYes
Dimensions65 x 57.5 mm
Distances58 x 49 mm
InputI2S
OutputI2S
DAC / ADC ChipES9028Q2M
Max sampling rateDSD1024
Max sampling rate768kHz
2 reviews
Very Good
I built a streamer-DAC on Volumio platform and this hat was simply surprising. With transformers output and a linear supply it gives great reproduction results. Smooth and clear timber, stable scene. To me it's really good solution, better than other I implemented in the past. Cost is a bit high but you will be rewarded with good sonic performance
This review has been posted for IAN CANADA DUAL MONO PLUS DAC ES9038Q2M HAT Raspberry Pi / I2S & SPDIF / PCM DSD
information
satisfait de mon achat mais a signaler que l'accessoire "IAN CANADA Contrôleur ESS SABRE 90X8 avec afficheur" n'est pas une option mais est obligatoire pour que la carte fonctionne!
