IAN CANADA HDMIPI PRO Ultra Low Jitter I2S LVDS HDMI Interface 32bit 1536kHz DSD1024
10%
Ian Canada's HdmiPi Pro is an I2S/DSD interface module via HDMI. It is the first solution to use a discrete 1bit LVDS driver to achieve the best HDMI signal quality and lowest noise levels. The module also incorporates the highly regarded 1bit discrete secondary reclockers (similar to ReClockPi) to ensure very low jitter. All in all, the HdmiPi Pro is the ultimate I2S HDMI interface for audiophiles looking to improve the sound quality of an external DAC.
Reduced price!
Reference : 16854
Limited special offer
165,00 €tax incl.
-10%
148,50 €tax incl.
123,75 € tax excl.
Ian Canada HdmiPi Pro
Ian Canada HdmiPi Pro Interface I2S LVDS HDMI Ultra Faible Jitter 32bit 1536kHz DSD1024
  • Discrete 1bit LVDS driver for best possible LVDS signal quality and very low noise.
  • Integrated discrete 1bit secondary reclocking stage.
  • Improved power supply filtering.
  • LDO-free design allows the use of a 3.3V battery or supercapacitor power supply for improved power performance.
  • Optimized impedance control for high speed LVDS signals.
  • Four layer PCB with dedicated shielding layers to eliminate EMI noise.
  • Ultra-low noise metal film resistors to ensure the lowest possible noise level.
  • PCM signals supported up to 1536kHz.
  • Native DSD signals supported up to DSD1024.
The HdmiPi Pro operates in SYNC clock mode and therefore must be paired with a FifoPiMa, FifoPiQ7 or FifoPiQ3 to operate (sold separately).
Product typeI2S interface
InputGPIO
OutputI2S LVDS via HDMI
Supported sampling ratesPCM up to 32bit 1536kHz
DSD up to DSD1024
Supply voltage3.3V
Dimensions95 x 56.5mm
Mounting holes spacing58 x 49mm
InputGPIO
Max sampling rateDSD1024
Max sampling rate1536kHz
Interface chipNC
Ian Canada's HdmiPi Pro is an I2S/DSD interface module via HDMI. It is the first solution to use a discrete 1bit LVDS driver to achieve the...
