IAN CANADA TRANSPORTPI MKII Low Jitter Digital Audio Interface Transmitter
The Ian Canada TransportPi MKII module is a low jitter digital audio interface compatible with the Raspberry Pi. It has been specifically designed in pure synchronous mode to achieve the best jitter performance. When combined with a Raspberry Pi and a FifoPi (sold separately), it creates an audiophile digital interface for Roon or other playback software. By adding a ReceiverPi (sold separately), it can also be configured as an S/PDIF FIFO or multi-source digital interface.
Reference : 16472
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 29-04-2025.
This product is not "stand alone". To work, this product must be connected to at least one FifoPI or Raspberry Pi.
Ian Canada TransportPi MKII Module Interface Audio Numérique Faible Jitter
Key features :
  • Pure synchronized clock architecture for best possible low jitter performance.
  • Built-in multi-stages S/PDIF reclocker.
  • Enhanced impedance matching network to ensure best possible S/PDIF signal quality.
  • High quality isolated S/PDIF output on RCA connector.
  • High quality non-isolated direct driven S/PDIF output on BNC connector.
  • Optical S/PDIF output on Toslink connector.
  • LVDC I2S / DSD / DoP digital audio output on HDMI connector (mode B).
  • 3.3VDC input makes it possible to use high quality ultracapacitor or LifePO4 battery power supply.
  • Up to 192kHz S/PDIF and 768kHz HDMI output.
  • Can work independently with other digital audio front ends with MCLK input (RPI free).
  • Possible to have independent DC power input.
Product typeDigital transport
Input1x GPIO
Outputs1x GPIO
1x I2S LVDS (HDMI)
1x BNC
1x Optical Toslink
1x Coaxial
SPDIF transmitter/receiverWM8805
LVDC CMOSTI DS90LV047A
Dimensions65 x 56.5mm
Mounting holes spacing57 x 49mm
InputGPIO
OutputGPIO
OutputI2S LVDS via HDMI
OutputBNC
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipWM8805
Max sampling rate768kHz
Interface chipWM8805
Maximum satisfaction
This review has been posted for IAN CANADA TRANSPORTPI MKII Low Jitter Digital Audio Interface Transmitter
The Ian Canada TransportPi MKII module is a low jitter digital audio interface compatible with the Raspberry Pi. It has been specifically designed...
