SUPTRONICS ST4000 DAC ES9018K2M HDMI I2S TCXO 32Bit / 384kHz for Raspberry Pi
3.0 / 5
Reference : 11848
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 24-04-2025.
Discover this exceptional DAC ST4000, equipped with the ESS SABRE ES9018K2M chip that can decode the signals up to 32Bit / 384kHz. The unique feature of this DAC is its ability to be driven by Raspberry Pi without driver,directly via the HDMI port.
This digital-to-analog converter featuring unprecedented features is ideal for transforming your Raspberry Pi 3 / Pi 2 into a true high-definition file player.
Equipped with the high-end SABRE ES9018K2M chip, connectorsgold plated and a TCXO 100MHz clock, this DAC will offer you musical sound, dynamic and rich in micro details.
Intended for the many open source software solutions dedicated to audio playback, it allows a simpler implementation than ever for an incomparable result and very high performance.
The ideal power supply for this ES9018K2M DAC is available as accessories: Power adapter Power supply 100-240V to 5.1V 4A.
WARNING !! :According to the distribution based on Linux Raspian kernel, the output HDMi I2s is limited in bitrate to 16bit 48khz.
Specifications:
  • DAC ESS SABRE:ES9018K2M
  • AOP stereo analog output chip: Burr Brown OPA 2604AU
  • THD + N: 120dB
  • Signal to noise ratio: 127dB
  • Output Level: 2V RMS
  • Ultra low precision TCXO 100MHz ultra low jitter clock
  • Inputs: HDMI / GPIO Raspberry Pi
  • Outputs: High quality stereo RCA Plated Gold / HDMI Plated Gold / Mini Toslink Optical
  • DC input on 5.5 / 2.1 mm Jack for power supply
  • Compatibilities: Moode Audio / OSMC / Openelec / Rune Audio / PiCorePlayer (Driver RPI DAC to I2S) / Etc ...
  • Supported Audio Formats: LPCM 2Ch / Dolby Digital 2 to 5.1Ch / DTS 2 to 5.1Ch
  • 100% compatible with ALLO KALI in I2S mode
  • Receiver and transmitter HDMI conform to HDMI 1.4 / 2.0a standards
  • Deep Full HD Support 12 bit, Full 3D, HDR and 4K2K 60Hz 420 video
  • Support HDCP 1.4 conversion to HDCP 2.2
  • Support HDCP 2.2 conversion to HDCP 1.4
  • Supports Repeater and HDCP 1.4 / 2.2 compliant
Supported sampling rates:
  • HDMI: 32Bit / 384kHz
  • I2S: 24Bit / 192kHz
  • Optical SPDIF: 24Bit / 192kHz
Dimensions / Packaging:
  • Supplied in 5V / 4A: power supply available in accessories
  • Supplied with 8 screws and 4 spacers M2.5 used to fix it on the Raspberry Pi (HAT format), as well as the gold-plated HDMI offset
  • Mounting Hole Distance (HAT): 50x58mm
  • PCB Dimensions: 85x87mm
  • Weight: 76g
  • Color PCB: black
Jumper de liaison à modifier ES9018K2M HDMI
Schéma technique DAC
InputI2S
OutputOptical Mini-Toslink
OutputHDMI
DAC / ADC ChipES9018K2M
Max sampling rate384kHz
Channel2 (Stereo)
A comparer avec les modèles de chez Hifiberry pour voir...
J'en possède une achetée ailleurs... et je suis resté sur ma faim.
Pour son prix, un simple dac, sans boîtier avec une telle fiche technique devrait faire bien mieux.
Il n'arrive même pas à la cheville de la sortie audio de mon macbook...
Une dynamic plate et une stéréo avec tellement peu de relief...
J'en garde un si mauvais souvenir que mon projet de faire de mon rasp une plateforme multimédia fut abandonné et je n'ai jamais pu le refourguer d'occase au passage (le dac).
Sinon il est bien fini et la fabrication semble de qualité, d'où la note moyenne, c'est froid et plat.
This review has been posted for SUPTRONICS ST4000 DAC ES9018K2M HDMI I2S TCXO 32Bit / 384kHz for Raspberry Pi
