SUPTRONICS X5500 DAC ES9023 Class D Amplifier TPA3118D2 Module for Raspberry Pi 2x30W 4 Ohm 24bit 192kHz
The Suptronics X5500 is a DAC and amplifier module that works as an extension of the Raspberry Pi (sold separately), interfacing between the two simply by using the 40-pin GPIO connector transmitting an I2S audio signal.
Reference : 17307
59,90 €tax incl.
49,92 € tax excl.
Last items in stock !
Shipping date: 24-04-2025.
Suptronics X5500
Suptronics X5500 Module DAC ES9023 Amplificateur TPA3118D2 pour Raspberry Pi 2x30W 4Ω 24bit 192kHz
The Suptronics X5500 is a DAC and amplifier module that works as an extension of the Raspberry Pi (sold separately), interfacing between the two simply by using the 40-pin GPIO connector transmitting an I2S audio signal. Its digital to analog conversion stage uses an ESS ES9023 chip capable of precise decoding with low jitter and supporting PCM audio streams up to 24bit 192kHz. Its Class D amplifier section embeds a TI TPA3118D2 chip capable of developing a 2x30W power under 8Ω BTL. For the rest, the X5500 maintains a high level of design quality and performance with notably the use of ultra-low noise voltage regulators, a high efficiency DC converter or a precise ALPS RK163 potentiometer. On the output side, the module provides a screw terminal for connecting speakers as well as a stereo RCA output. An XH2.54mm connector also allows to power supply external modules with 5VDC.
The module supplies power to the Raspberry Pi (sold separately) to which it is connected. Therefore, there is no need for an additional power supply for the Raspberry Pi.
Product typeDAC and amplifier module
InputI2S via GPIO
Outputs1* Stereo RCA
Speaker outputs (screw terminal)
DAC chipESS ES9023
Amplification chipTI TPA3118D2
Amplification typeClass D
Max power2x30W @ 4Ω BTL, 24VDC
Supported sampling rates (Raspberry Pi I2S)PCM up to 24bit 192kHz
RCA output level2Vrms
Hardware compatibilityRaspberry Pi 1 Model B+
Raspbery Pi 2 Model B
Raspberry Pi 3 Model B
Raspberry Pi 3 Model B+
Raspberry Pi 4 Model B
Compatible OSMoode Audio
OSMC
OpenElec
Raspbian Jessie
Volumio
piCorePlayer
Dynamic range112dB
Supply voltage6-26VDC via Jack 5.5/2.5mm (power supply sold separately)
PCB dimensions85*57mm
Package1* Suptronics X5500
Screws and spacers
The Suptronics X5500 is a DAC and amplifier module that works as an extension of the Raspberry Pi (sold separately), interfacing between the two...
