AUDIOPHONICS DAC Sabre ES9023 V2.1 I2S to Analogue 24bit / 192kHz
A converter with an unbeatable price-performance ratio and direct analog outputs, this module is ideal for all DIY applications. Equipped with the now famous SABRE ES9023 (equipping our U-SABRE), Ultra low noise "ON" regulator and OS-CON capacitor.
4.7 / 5
Reference : 8396
15,90 €tax incl.
13,25 € tax excl.
This product has been replaced by the new version, the DAC Sabre ES9018K2M I2S to RCA 32bit 384kHz DSD256.
AUDIOPHONICS DAC ES9023 V2.1
Sabre ES9023 DAC I2S to Analog 24bit/192kHz
Audiophonics DAC Sabre ES9023 V2.2 I2S vers Analogique 24bit/192kHz
A converter with an unbeatable price-performance ratio and direct analog outputs, this module is ideal for all DIY applications. Equipped with the now famous SABRE ES9023 (equipping our U-SABRE), Ultra low noise "ON" regulator and OS-CON capacitor this DAC will offer you a musical sound and rich in micro details. Its high versatility allows it to also be used directly at the output of a Raspberry PI via the GPIO.
Usable WITH :
Volumio
piCorePlayer
Dimensions
External Master Clock
DAC9023 custom clock
It is possible to inject a MCLK (external master clock) signal by removing resistor R2
Product typeDAC
ConversionESS ES9023
InputI2S
Supported sampling rateUp to 24bit 192kHz
Space available for additional clock-
I2S ConnectionOrange : MCLK
Yellow : GND
White : DATA
Red : LRCK
Black : BCK
Power supply connectionBlack : GND
Red : +5V
Dimensions53.2 x 47.4mm
Cables1.13mm² / AWG16
Wires0.08mm² / AWG28
Space between fixation holes43.1 x 38.1mm
RCA Spacing20mm
Package1x Audiophonics DAC Sabre ES9023
1x I2S Cable (5 pins)
1x Power supply cable (2 pins)
Mounting diagram
Channel
  • 2 (Stereo)
Input
  • I2S
Output
  • RCA
DAC / ADC Chip
  • ES9023
Max sampling rate
  • 192kHz
14 reviews
An excelent simple DAC
This DAC ,despite its sophisticated internal architecture is simple to attach to RPI4, no boring I2C control, OPA necessary, worked immediately with Volumio generic DC i2S driver. I connected it to TI 2x50 W TPA3116D2 chip amp. With two Magnat premium 102 speakers the set generates great sound, for a daily listening. Can compare to PCM5102A which I installed to another DIY DAC, both are good ones, Sabre seems to me better in high freq, IT in lower ones. May be its a little bit subjective view.
This review has been posted for AUDIOPHONICS DAC Sabre ES9023 V2.1 I2S to Analogue 24bit / 192kHz
Le jour et la nuit...
Acheté pour transformer un vieux RASPBERRY PI 1B (2011) en lecteur mp3 et numérique sédentaire pilotable à distance.
Fonctionne parfaitement, pas de bruits de fond, de clics ou parasites, bon niveau de sortie ligne.
En comparaison de mon IPOD CLASSIC 160Go qui me servait précédemment pour cet usage, c'est le jour et la nuit, graves plus présents et surtout mieux maitrisés, des aigus plus détaillés sans être agressifs ni sibilants, des voix bien détachées et présentes, la dynamique d'ensemble est elle aussi nettement supérieure, la scène sonore est mieux établie, bref je suis comblé et je ne pensais pas pouvoir avoir cette qualité de rendu sur du simple mp3.
Non testé sur des formats CD et au delà, je penses que c'est là où le DAC montrerait ses limites face à mes lecteurs CD et DAC audiophiles autonomes ...
J'aurais juste souhaité un schéma de montage papier joint au DAC ou au moins une explication plus détaillée sur la fiche produit car j'ai monté le DAC sans être trop certain de ce que je faisais.
Note : utilisé sur une installation audio entrée de gamme avec double amplification CAMBRIDGE AUDIO et des enceintes colonnes JBL très dynamiques.
Bon rendu sonore mais...
Connecté à un Raspberry Pi sous Volumio, la qualité est très bonne connecté à l'entrée AUX de ma chaine hifi. Par contre attention aux indications de connexion sur le site Audiophonics, les couleurs des fils du connecteur ne correspondent pas du tout. Autre défaut: il n'y a pas de contrôle de volume donc pas utilisable sur l'entrée LINE d'une enceinte portable comme je l'avais prévu au départ (niveau de sortie beaucoup trop élevé).
RAS
Fonctionne comme specifie. Tres bon rapport qualite / prix. Cable sur un Linkplay A31 et le rendu sonore est tres honnete!
Bon petit DAC
Très bon DAC utilisé derrière une interface SPDIF. Son très bien restitué. carte facile a mettre en oeuvre. Rien à redire.
A converter with an unbeatable price-performance ratio and direct analog outputs, this module is ideal for all DIY applications. Equipped...
