AUDIOPHONICS DIGIPI+I2S Digital Interface WM8804G for Raspberry Pi SPDIF I2S TCXO
This Audiophonics DigiPi+I2S interface expands the output connectivity of a Raspberry Pi, giving it an additional panel of digital audio outputs. It includes a Toslink optical output and a coaxial output, but also an I2S LVDS output via HDMI. Thus, equipped with the DigiPi+I2S interface and an efficient software solution, your Raspberry Pi can be transformed into a real high fidelity network player.
4.7 / 5
Reference : 15821
54,90 €tax incl.
45,75 € tax excl.
This interface needs a Raspberry Pi 3, Pi 4 or Pi 5 to work. This is sold separately.
Audiophonics DigiPi+I2S Interface Numérique WM8804G pour Raspberry Pi SPDIF I2S TCXO
Connecting the Raspberry Pi to the interface is very simple in I2S using the integrated 40-pin GPIO connector.
The DigiPi+I2S uses the HiFiBerry Digi standard. It is therefore compatible with Volumio or Moode Audio, free and extremely complete software solutions based on Raspberry Pi. Each one has many features to enrich the playback. Moreover, it is a software environment specially developed for this type of hardware, so the whole thing will work to the best of its abilities.
To work properly, the DigiPi+I2S needs to use the HiFiBerry driver. This is called HiFiBerry Digi(Digi+) on moOde Audio and HiFiBerry Digi on Volumio.
WM8804G Interface & TCXO Clock
The interface works with a WM8804G digital chip. It is connected to the Raspberry Pi by I2S via GPIO and the precision of the digital stream is ensured by a TCXO Audiophonics 27MHz 0.1ppm clock. Thanks to this configuration, the interface is able to handle sample rates up to 24bit 192kHz with a particularly low distortion and jitter rate.
A power supply that adapts to your needs
In order to give you the freedom to make the best decision in terms of power supply, the DigiPi+I2S interface will be able to adapt to different power supply configurations. The interface and the Raspberry can be powered via a DC 5.5/2.5mm jack input. The reverse is also possible and the interface can be powered directly via the Raspberry Pi GPIO.
Configuration 1 : The Raspberry Pi powers the DigiPi+I2S.
Configuration 2 : The DigiPi+I2S powers the Raspberry Pi.
Product typeDigital interface
InputGPIO (I2S)
Outputs1x Optical Toslink
1x Coaxial
1x I2S LVDS via HDMI
Digital interface chipWM8804G
Max sampling ratesPCM 24bit 192kHz
DSD DoP64
Compatible softwareVolumio
moOde Audio
Raspberry Pi compatibilityPi 3 / Pi 4 / Pi 5
Supply voltage5VDC via Jack DC 5.5/2.5mm or via GPIO
Dimensions85 x 56mm
Mouting holes spacing58 x 49mm
Weight56g
Package1x Audiophonics DigiPi+I2S
Screws and spacers
InputI2S
OutputOptical Toslink
OutputCoaxial SPDIF
OutputI2S LVDS via HDMI
DAC / ADC ChipWM8804
Max sampling rate192kHz
Interface chipWM8804
3 reviews
RPIG 8Go Target + GENTOOPLAYER + DIRETTA + RPI4 8Go Host + Musician Pegasus
Connectée sur le RPI Target (diretta - Gentooplayer) pour se passer de la connexion USB.
Le bon qualitatif est spectaculaire, son plus précis, une très belle scène sonore.
Je pensais la gestion des DSD, limitée aux DSD64 et en DOP une limitation, mais il n'en est rien.
Si on y réfléchit bien, le DSD est essentiellement un outil marketing car les véritables enregistrements directement effectués en DSD sont extrêmement rares et ne plairons pas forcément à tout Lem monde car ne passent pas par la case mise à plat, mixage, prod...C'est du brut de chez brut !
Pour les utilisateurs du DAC Musician Pegasus, le Mode 4 de l'i2s est fonctionnel à 100%, sans inversion des canaux, n'y de la passe.
eN résumé, une très bonne petite carte I2S LDVS, à un tarif plutôt contenu.
A savoir maintenant si un passage vers la solution Ian Canada (pratiquement 300€ au total) apporterait un plus significatif.
This review has been posted for AUDIOPHONICS DIGIPI+I2S Digital Interface WM8804G for Raspberry Pi SPDIF I2S TCXO
Great for RaspberryPi 3B
Runs smoothly in my volumio setup and sounds awesome. Fast delivery, thanks Audiophonics.
Endpoint Roon HDMI LVDS super facile à faire
Super pette carte pour fabriquer facilement un endpoint Roon. Je l'alimente depuis la carte directement avec une alimentation 5V 6A.
This Audiophonics DigiPi+I2S interface expands the output connectivity of a Raspberry Pi, giving it an additional panel of digital audio outputs....
