AUDIOPHONICS I-SABRE V2.1 DAC ES9023 TCXO Raspberry Pi 3 / Pi 2 A+ B+ / I2S
4.8 / 5
Reference : 11917
44,90 €tax incl.
37,42 € tax excl.
Updated I-Sabre TCXO V2, its architecture is designed to allow you to have all the outputs on the same side when the Raspberry Pi is coupled to the DAC.
This version 2.1 has been redesigned to simplify the connection of the OLED Wins screentar WEH001602Aand to easily integrate an external power control module (ex: PI-SPC Pre-welded ATX power control module)
Our specially designed aluminum boxes make it easy to integrate the DAC (sold separately).
This module is ideal for transforming a Raspberry Pi 2.0, A + or B + into a high-definition file player. This converter offers unbeatable value for money with direct analog outputs on high-quality headers.
Equipped with the now famous SABRE ES9023 (equipped with our U-SABRE), Ultra low noise "ON" regulator and condenser OS-CON this DAC will offer you musical sound and rich micro details.
Its high versatility (GPIO B + or A + HAT format connector (for PI) as well as I2S inputs) allows it to be also usable from a USB interface or any I2S source.
Features:
  • High Precision Clock TCXO 0.5ppm ultra low jitter
  • I2S input on 5 pin XHP connector
  • DC Input Jack 5V - External Diameter 5.5mm / Internal Diameter: 2.1mm (not required if the PI is powered by the Micro USB port)
  • Input: Raspberry PI B + A + 2.0 GPIO and I2S
  • Output: RCA High Quality Gold Plated
  • Supported sampling rates: 24bit 192kHz
  • No welding required
  • Supplied with 4 nuts, 4 screws and 4 spacers M2.5 to fix it on the PI B +, A + or 2.0 (HAT format)
  • Spacing: 50mm, 58mm
  • PCB Dimensions: 85x56x33mm
  • I2S driver: Hifiberry DAC
  • Volume fixed under Volumio in bitperfect
Dimensions and weight:
  • Dimensions: L x W x H: 106x56x32.5mm (overall)
  • Center distance fixing: 50x60mm
  • RCA cinch distance: 20mm
  • Weight 64gr.
Can be used with:
  • Raspberry Pi Model B + 512MB - HDMI Ethernet 2xUSB
  • Raspberry Pi Model A +256MB HDMI USB
  • Raspberry Pi 2 1GB HDMI 1.4 USB 2.0 1080p
  • AMANERO Combo 384 Digital interface USB 384khz to I2s / DSD
  • Audiophonics SA9023 Interface USB to I2S / SPDIF 24bit / 96khz
  • AMC DAC PCM2706 Digital Interface USB -16 / 48khz Coax / Opt / I2s
  • Audiophonics U-XMOS192 digital interface USB to I2S / DSD / Spdif
  • Audiophonics U-XMOS384 digital interface USB to I2S / DSD / Spdif
  • LJ CM6631A Interface USB to I2S / SPDIF 24bit / 192khz
  • LJ TE7022 Interface USB to I2S / SPDIF 24bit / 96khz
Max2Play Volumio piCorePlayer
OLED, IR AND I2S DISPLAY CONNECTIONS
INTEGRATION DIAGRAM ATX POWER CONTROL MODULEIntégration du module de contrôle d'alimentation ATX
SPECIFIC RATINGS OF REAR LOCATION WITH PI 3:
Cotations I-Sabre V2.1
Mounting typeTo screw
Channel2 (Stereo)
5 reviews
Excellent rapport qualité prix
Carte livrée en 48h, bien emballée. Ça change l’approche de la hi-fi que j’avais pour le moment ... là je retrouve vraiment une super qualité de son. Sur volumio impossible de trouver le bon driver, du coup j’ai testé avec moode et là tout fonctionne parfaitement le tout avec une tite appli iPhone et c’est parfait ou même par le navigateur de la TV ... très bon achat. Pour 80€ on peut se faire une solution au résultat très honorable !!!
Bonjour,
Sous volumio vous pouvez utiliser tout driver générique (RPI DAC, ES9023, Hifiberry DAC etc...) Moode est un bon choix et est sensiblement plus stable.
This review has been posted for AUDIOPHONICS I-SABRE V2.1 DAC ES9023 TCXO Raspberry Pi 3 / Pi 2 A+ B+ / I2S
Excellent produit
Acheté pour un projet de lecteur réseau sous piCorePlayer, la carte remplit parfaitement son rôle. Sortie RCA de bonne facture, pas de bruit ou de parasite en l'alimentant via l'entrée Jack 5V ou le port micro USB.
Rien à signaler concernant la qualité audio.
Excellent produit pour mon usage.
A little gem
It is an amazing DAC and not only for its price. I also have the old V2.0. Maybe the best available implementation of ES9023 with the 0.5 ppm TCXO. I am using it with an Allo Kali I2S reclocker and separated power supply for RPi, Allo Kali and I-Sabre DAC.
It is not so well known, but the ES9023 is able to run at 32bit/192kHz with miraculous sound. The moOde player with its custom kernel can feed the ES9023 with 32bit I2S data, however the libsoxr up-sampler library runs only on 28 bit internally by default in case of the Very High quality settings. High quality means only 20 bit. Unfortunately MPD doesn't allow so much configuration options for libsoxr. To overcome on this issue, you should download the latest source code of libsoxr. Change only one line in the code to allow libsoxr to run on 32 bit internally in case of Very High quality settings. Then you should compile it and replace the existing libsoxr in moOde player. The difference is really well audible.
Excellent raport qualité prix
J'ai acheté ce DAC pour me faire un RASPTouch avec une Pi3 et un contrôleur ATX avec KODI sur XBian. Configuration basique facile, est reconnue comme un DAC Hifiberry, donc quasi natif sur une Xbian.
Le son est à la hauteur, voir au delà de mes attentes. Les graves autant que les aigus sont restitués avec une grande finesse.
Je le conseille sans aucun problème. Pour ceux qui veulent moins de composants, la V3 intègre un module de contrôle d'alimentation, on pourrait donc se passer d'un contrôleur ATX...
perfect sound
It took long to decide which DAC I should buy, finally I ordered also the AUDIOPHONICS Linear Regulated Low Noise Power Supply USB 5V 3.5A 25VA and in just 5 minutes the setup was playing.
I am really surprised that a DAC can do so much in the sound on the same setup.
So the source is indeed the first important step.
At this price a big improvement over the HiFiberry DAC+ Pro
