IAN CANADA TRANSPORTPI DIGI Ultra Low Jitter Digital Audio Interface Module
The TransportPi Digi is a high performance all-in-one digital audio interface for the Raspberry Pi. It provides ultra-low jitter and low noise signal quality using IAN CANADA's proprietary 3-stage 1-bit discrete reclocking technology for SPDIF signals, and 2-stage multi-bit for I2S signals.
Reference : 16714
125,00 €tax incl.
104,17 € tax excl.
Shipping date: 25-04-2025.
Ian Canada transportpi digi
Ian Canada TransportPi Digi Module Interface Audio Numérique
The TransportPi Digi also features two XO / OCXO clock slots for even higher sound quality. Its multitude of outputs (Coaxial, Optical, HDMI, GPIO) makes it a very complete and versatile module.
This product combined with a very good power supply like the UcPI or PurePi makes it one of the best digital interfaces for Raspberry Pi on the market.
This TransportPi Digi is functionally equivalent to an I2S FIFOPI re-clocker + a TransportPi MKII.
Key points:
  • 4 high quality reclocked outputs: SPDIF, Optical, I2S, GPIO
  • 3-stage discrete 1-bit reclocking for SPDIF signals
  • 2-stage multi-bit discrete reclocking for I2S signals
  • Pre-installed 45.1584/49.1520 MHz local low noise clocks compatible with FiFoPi
  • High quality local MCLK output on U.FL coaxial connector
  • Can also operate as an I2S FIFO re-clocker
  • Clean low noise 3.3V/5V power input: ideal for working directly with a LifePO4 battery. The built-in LDO can also be bypassed.
  • Can share power with the Raspberry Pi
  • Works with SinePi to take high quality external sine clocks
  • Supports PCM signals up to 192kHz
  • Four-layer PCB design with two inner PCB layers as dedicated shielding plates to further reduce noise
  • Enhanced power supply filter network with over 130 ultra-low ESR decoupling capacitors
  • Uses the standard WM8805 Linux driver
  • Bit-perfect and lossless
  • Easy-to-use plug-and-play
Ian Canada TransportPi digi dimensions
Le module Ian Canada TransportPi Digi est vendu seul. Le Raspberry Pi est vendu séparément.
Technical specifications
Type of productDigital nterface
Input1x GPIO
Outputs1x GPIO
1x I2S LVDS (HDMI)
1x Toslink Optical
1x Coaxial
SPDIF Receiver/TransmitterWM8805
Dimensions75 x 56.5mm
Spacing58 x 49mm
InputGPIO
OutputGPIO
OutputOptical Toslink
OutputCoaxial SPDIF
OutputI2S LVDS via HDMI
DAC / ADC ChipWM8805
Max sampling rate192kHz
Interface chipWM8805
7 reviews
Great product.
Very good quality and sounds very nice.
This review has been posted for IAN CANADA TRANSPORTPI DIGI Ultra Low Jitter Digital Audio Interface Module
A bargain
I bought this based on positive reviews, but expected them to be hyperbole. This replaced an IQaudIO Digi+ board and was a massive improvement. Overall clarity was similar, but my system suffered in sounding hyper clear but 2D. The Ian Canada board brought weight, body and a huge amount of depth. Things are very 3D. I was not a believer that streamers could make much difference if well engineered. Well either the commercial product market is full of sub-competent engineering, or the focus on creating a low noise, ultra low jitter source with hyper accurate clocking makes more difference than those over at ASR website claim. I have enjoyed my last 2 weeks with this board and a UcPi that I've just plumped for all the flagship boards to make a no-holds-barred streamer. I reckon just this Ian Canada board I am reviewing is one of the best bargains of about 30 years in high end hifi. Those old 70s and 80s recordings that on modern digital streaming services sounded thin or cheesey now sound full 3D and immersive. More modern stuff is just more so, or louder. Everything is now like a live performance.
Jaroslav B.
The device is functional, but the oscillators came incorrectly fitted. 2x 49.1520 MHz are fitted instead of 1 x 49.1520 MHz and 1 x 45.1584
Maximum satisfaction
Amazing streamer for the money
Amazing device, I use it with Accusilicon clocks (45 and 49). Super soundstage, calm, fantastic!
The TransportPi Digi is a high performance all-in-one digital audio interface for the Raspberry Pi. It provides ultra-low jitter and low noise...
