Connect your JustBoom DAC to a set of active speakers, headphones or audio amplifier and you can be up and running right away, enjoying high-quality audio playback in minutes after unpacking.
Si you need amplification or additional outputs for passive speakers, the JustBoom DAC is also compatible with the JustBoom amp. Simply stack it with the amp on the mounting hardware you will get a complete Hifi audiophile system.
This affordable and standalone DAC is among the best value for money in the market for versatile audio playback, high quality. The integrated DAC chip offers a 32 bit 384kHz resolution (Limited to 24bit / 96khz on the SPDIF). The JustBoom DAC also includes a 138mW headphone amplifier on a 3.5mm jack.
A simple 5 volt Micro USB type Smartphone, tablet is enough to operate the JustBoom DAC!
Find here all JustBoom editing guides:
Here are some possible uses for the JustBoom DAC:
JustBoom Test - How to turn a Raspberry nano computer into a multiroom audio system
