Très bon produit.
Branché en Toslink sur un ampli Marantz PM-6006.
La qualité sonore est très satisfaisante en lecture de fichiers FLAC.
Le module est automatique ment reconnu par Volumio : même pas besoin de le selectionner dans la liste.
Here is the digital interface JustBoom Digi HAT , a high-resolution audio output for the SBC Raspberry Pi . Plug & Play and HAT (Hardware Attached on Top), making it a direct interface by plugging it into your Raspberry Pi A +, Pi B +, Pi 2 or the new Pi 3. The JustBoom Digi HAT high quality sound, and unmodified digital audio data stream for Bit-Perfect transmission to your HiFi system .
The JustBoom Digi HAT has been designed to be simple and easy to install with a Rasberry Pi. Without any soldering required and with the supplied mounting hardware, this digital interface is suitable for both seasoned DIY professionals and absolute beginners.
Simply connect your Digi HAT to an external DAC, amplifier or pre-amplified speakers for immediate operation and high-quality sound and audio playback. An Infraro receiveruge (IR) is also supplied to allow you to remotely control your digital interface (welding required).
The JustBoom Digi HAT features a low-jitter 24Bit / 192kHz audio conversion chip and a Bit-Perfect SPDIF digital output on an Optical or Coaxial connector for a lossless audio experience. It also includes an output transformer for complete galvanic insulation between your Raspberry Pi and your DAC on the Coaxial output.
You will find on the Justboom website a mounting guide with the Raspberry Pi (In English): Set Up Your JustBoom Digi HAT and Case .
Find here all JustBoom editing guides:
Main Features :
Specifications:
JustBoom Test - How to turn a Raspberry nano computer into a multiroom audio system
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
LAURENT C.
